Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The Dell Inspiron 11 i3147 battery may be need to be replaced if it has lost its ability to hold a charge or does not fully charge. This guide will show you how to remove the old battery and replace it with a new one.
If your battery is swollen, it may be punctured. This is dangerous, so follow these precautions.
Make sure the device is turned off before you begin.
The old battery is considered a rechargeable battery, so dispose of it properly at your local recycling facility.
  1. Close the computer and turn it over, with the bottom of the computer facing up.
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Remove the nine 7.6 mm PH0 screws on the cover.
    • Remove the nine 7.6 mm PH0 screws on the cover.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Use a plastic opening tool to remove the cover from the computer.
    • Use a plastic opening tool to remove the cover from the computer.
  5. Remove the three 4.7mm PH0 screws that secure the battery to the computer.
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  6. Remove the hard drive cable from the battery.
    • Remove the hard drive cable from the battery.
  7. Lift the battery from the computer.
    • Lift the battery from the computer.
    • Replace old battery with new one.
Abschluss
Muhammad Erchid
1.051 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G6, Leahy Fall 2018 Mitglied von USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 122
