Zum Hauptinhalt wechseln
Dell Inspiron 11 i3147 Camera Replacement
Was du brauchst
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: Schritt 1, Bild 1 von 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: Schritt 7, Bild 1 von 1
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: Schritt 8, Bild 1 von 1
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: Schritt 9, Bild 1 von 1
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: Schritt 10, Bild 1 von 1
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: Schritt 11, Bild 1 von 1
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: Schritt 12, Bild 1 von 1
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 11 i3147 Camera Replacement: Schritt 13, Bild 2 von 2
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: Schritt 15, Bild 1 von 1
    • Use a plastic opening tool to take the camera module off the display.
Abschluss
Muhammad Erchid
1.051 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G6, Leahy Fall 2018 Mitglied von USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 202
