Zum Hauptinhalt wechseln
Dell Inspiron 11-3138 Battery Replacement
Was du brauchst
  1. Dell Inspiron 11-3138 Battery Replacement, Disconnect the Battery Cable: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 11-3138 Battery Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the screws that secure the battery to the palm-rest assembly.
  3. Dell Inspiron 11-3138 Battery Replacement, Lifting the Battery: Schritt 3, Bild 1 von 1
    • Lift the battery, along with its cable, off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
  4. Dell Inspiron 11-3138 Battery Replacement, Align the Screw Holes: Schritt 5, Bild 1 von 1
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly and place the battery on the palm-rest assembly.
  5. Dell Inspiron 11-3138 Battery Replacement, Replace the Screws: Schritt 6, Bild 1 von 1
    • Replace the screws that secure the battery to the palm-rest assembly.
  6. Dell Inspiron 11-3138 Battery Replacement, Connecting the Battery Cable: Schritt 7, Bild 1 von 1
    • Connect the battery cable to the system board.
Abschluss
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 283
