Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Remove the screws that secure the hard-drive assembly to the palm-rest assembly.
Using the pull-tab, disconnect the hard drive cable from the system board.
Lift the hard-drive assembly, along with its cable, off the palm-rest assembly.
Remove the screws that secure the hard-drive brackets to the hard drive.
Align the screw holes on the NEW hard drive with the screw holes on the hard-drive bracket.
Replace the screws that secure the hard-drive brackets to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
Replace the screws that secure the hard-drive assembly to the palm-rest assembly.
Connect the hard-drive cable to the system board.
