Zum Hauptinhalt wechseln
Dell Inspiron 11-3147 CMOS Battery Replacement
Was du brauchst
  1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: Schritt 1, Bild 2 von 2
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 CMOS Battery Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic spudger, gently press under the battery to lift it up and out.
  3. Dell Inspiron 11-3147 CMOS Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the CMOS Battery
Abschluss
William Brum
755 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 43
Insgesamt: 3,291
