Zum Hauptinhalt wechseln
Dell Inspiron 11-3147 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 11-3147 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3147 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Using the tab on the cables connector with your hand unplug the Hard Drive connection cable and remove it from the cable track on the battery.
  3. Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Pull back the sticker covering the first screw on the hard drive chaises.
    • Useing a Philips Head #0 screwdriver remove the three screws holding the drive in place.
  4. Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Lift the hard drive from the left side as depicted and remove.
  5. Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Unplug the adapter cable from the drive. No tool is required for this step.
  6. Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 11-3147 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Using a Philips Head #1 Screwdriver remove the four screws holding the hard drive to the chassis.
    • Remove the drive from the chassis. Care that the drive does not fall out once all the screwshave been removed.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
William Brum
755 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
I am a visual learner and with this guide, I had my hard drive changed and the backplate back on in less than 10 minutes. Thanks for the great guide.
Chris Hartfield - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 5,516
