Zum Hauptinhalt wechseln
Dell Inspiron 11-3152 Battery Replacement
Was du brauchst
  1. Dell Inspiron 11-3152 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3152 Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 11-3152 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 Battery Replacement: Schritt 3, Bild 1 von 1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 Battery Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 11-3152 Battery Replacement: Schritt 5, Bild 2 von 2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery from the computer system by gently lifting it from the side.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 4-6, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-6, Catania Spring 2016
UMASSD-CATANIA-S16S4G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 781
