Zum Hauptinhalt wechseln
Dell Inspiron 11-3152 USB Port Replacement
Was du brauchst
  1. Dell Inspiron 11-3152 USB Port Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3152 USB Port Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 USB Port Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 11-3152 USB Port Replacement: Schritt 2, Bild 2 von 2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 USB Port Replacement: Schritt 3, Bild 1 von 1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 USB Port Replacement, Battery: Schritt 4, Bild 1 von 1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 USB Port Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 11-3152 USB Port Replacement: Schritt 5, Bild 2 von 2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 USB Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 USB Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery from the computer system by gently lifting it from the side.
  8. Dell Inspiron 11-3152 USB Port Replacement, USB Port: Schritt 8, Bild 1 von 1
    • Remove the two white power connectors on the bottom right of the motherboard by gently pulling on the tabs backward.
  9. Dell Inspiron 11-3152 USB Port Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 11-3152 USB Port Replacement: Schritt 9, Bild 2 von 2
    • Gently peel the tape on top of the power connectors that link the Solid State Drive to the motherboard.
    • Use spudger to lift and detach the power connector from the motherboard.
  10. Dell Inspiron 11-3152 USB Port Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 11-3152 USB Port Replacement: Schritt 10, Bild 2 von 2
    • Detach the purple ZIF connector and the white ribbon connector. This can be done by using a spudger to unlock the ZIF connector and pull the cable out.
    • Pull the ribbon cable that connects the keyboard to the motherboard away.
  11. Dell Inspiron 11-3152 USB Port Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 11-3152 USB Port Replacement: Schritt 11, Bild 2 von 2
    • Slide the ZIF cord connecting to the Solid State Drive towards itself to detach it from the motherboard.
  12. Dell Inspiron 11-3152 USB Port Replacement: Schritt 12, Bild 1 von 1
    • Unscrew the two 2mm screws on the silver brace in the top right of the laptop using a #0 Phillips head.
  13. Dell Inspiron 11-3152 USB Port Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 11-3152 USB Port Replacement: Schritt 13, Bild 2 von 2
    • Unscrew six 1mm screws holding down the motherboard using a #0 Phillips head.
  14. Dell Inspiron 11-3152 USB Port Replacement: Schritt 14, Bild 1 von 1
    • Lift up the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 4-6, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-6, Catania Spring 2016
UMASSD-CATANIA-S16S4G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 395
