Einleitung
In this guide, we will show you how to remove and replace the Display Assembly.
Was du brauchst
Remove the screw that secures the display-cable bracket to the system board.
Slide and lift the display-cable bracket off the system board.
Open the latch and disconnect the display cable from the system board.
Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
Slide and lift the palm rest and keyboard assembly off the display assembly.
Place the NEW display assembly on a flat and clean surface.
Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
Slide the display cable into the connector on the system board and close the latch to secure the cable.
Slide the display-cable bracket into the slot on the palm rest and keyboard assembly.
Align the screw hole on the display-cable bracket with the screw hole on the system board.
Replace the screw that secures the display-cable bracket to the system board.
