Zum Hauptinhalt wechseln
Dell Inspiron 11-3164 Mousepad Replacement
Was du brauchst
  1. Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: Schritt 1, Bild 2 von 2
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. Dell Inspiron 11-3164 Mousepad Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 11-3164 Mousepad Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Dell Inspiron 11-3164 Mousepad Replacement: Schritt 3, Bild 1 von 1
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  4. Dell Inspiron 11-3164 Mousepad Replacement: Schritt 4, Bild 1 von 1
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  5. Dell Inspiron 11-3164 Mousepad Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 11-3164 Mousepad Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 11-3164 Mousepad Replacement: Schritt 5, Bild 3 von 3
    • With tweezers, disconnect the keyboard cable
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
    • Gently remove the mouse touchpad.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S6-G4, Eyestone Spring 2018 Mitglied von USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 205
