Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
Use your screw driver to remove the plastic cover in the center of the laptop.
Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
Use your metal pry tool to pry around the laptop until the two pieces separate.
Use your metal pry tool to release the connector.
Remove the speaker plug from it's socket.
Lift the speaker assembly from the case.
Fast fertig!
Abschluss
