Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit. Use your screw driver to remove the plastic cover  in the center of the laptop.
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Use your metal pry tool to pry around the laptop until the two pieces separate. There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Remove the speaker plug from it's socket. Lift the speaker assembly from the case.
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
Abschluss
USF Tampa, Team S6-G4, Eyestone Spring 2018 Mitglied von USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 81
