Zum Hauptinhalt wechseln
Dell Inspiron 11-3168 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 11-3168 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3168 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 2 Dell Inspiron 11-3168 Hard Drive Replacement, Hard Drive: Schritt 6, Bild 2 von 2
    • Unscrew the two 7.5 mm Phillips #00 screws.
  7. Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 11-3168 Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Lift the hard drive out of the laptop.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 2,434
