Zum Hauptinhalt wechseln
Dell Inspiron 11-3168 Memory modules Replacement
Was du brauchst
  1. Dell Inspiron 11-3168 Memory modules Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3168 Memory modules Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Memory modules Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 11-3168 Memory modules Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 11-3168 Memory modules Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Memory modules Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 11-3168 Memory modules Replacement: Schritt 3, Bild 2 von 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Memory modules Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 11-3168 Memory modules Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Memory modules Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 11-3168 Memory modules Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 11-3168 Memory modules Replacement: Schritt 5, Bild 3 von 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: Schritt 6, Bild 1 von 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: Schritt 6, Bild 2 von 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: Schritt 6, Bild 3 von 3
    • Press down on the two latches on either side of the memory module.
    • Lift and remove the memory module.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 739
