Zum Hauptinhalt wechseln
Dell Inspiron 11-3168 Wifi module Replacement
Was du brauchst
  1. Dell Inspiron 11-3168 Wifi module Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3168 Wifi module Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Wifi module Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Wifi module Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 3, Bild 2 von 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Wifi module Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Wifi module Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 5, Bild 3 von 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: Schritt 6, Bild 1 von 3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: Schritt 6, Bild 2 von 3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: Schritt 6, Bild 3 von 3
    • Use an opening tool or your fingers to release the clamps on both ends of the ribbon cable and lift away.
  7. Dell Inspiron 11-3168 Wifi module Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 7, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the screw that is holding the WiFi module in place.
    • Remove the metal piece that covers the antenna cable connectors.
  8. Dell Inspiron 11-3168 Wifi module Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 8, Bild 3 von 3
    • To remove the WiFi module from the motherboard, slide it free of the socket connector.
  9. Dell Inspiron 11-3168 Wifi module Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 11-3168 Wifi module Replacement: Schritt 9, Bild 3 von 3
    • Disconnect both the black and the white wires from the WiFi module.
Abschluss
To install the replacement module, start at step 4 and work your way backwards to step 1.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 509
