Einleitung
The CD Drive is used to read and write CDs. The CD Drive is delicate and can be easily broken which could lead to it needing replacement.
Was du brauchst
Unscrew the one 8mm Phillips #0 screw immediately below the RAM compartment and remove the panel.
Unscrew the one Phillips #0 screw at the bottom of the RAM compartment cover, and remove the RAM compartment cover.
Fast fertig!
Abschluss
