Einleitung
In this guide, we will show you how to remove and replace the Display Assembly.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Follow the instructions in Before You Begin.
    • Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Disconnect the display cable from the system board connector.
    • Disconnect the display cable from the system board connector.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the two screws (one on each side) that secure the display assembly to the computer base.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Lift and remove the display assembly off the computer base.
    • Lift and remove the display assembly off the computer base.
  7. Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Connect the display cable to the system board connector.
    • Connect the display cable to the system board connector.
  9. Route the Mini-Card antenna cables through the routing guides on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  10. Connect the Mini-Card antenna cables to the Mini-Card(s).
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Abschluss
Terrence15
70.547 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 29
