Zum Hauptinhalt wechseln
Dell Inspiron 1122 M102z Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • Follow the instructions in Before You Begin.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 1122 M102z Hard Drive Replacement, Disconnecting the Hard Drive: Schritt 2, Bild 1 von 1
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Bracket: Schritt 5, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard Drive: Schritt 6, Bild 1 von 1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard-Drive Assembly: Schritt 8, Bild 1 von 1
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 1122 M102z Hard Drive Replacement, Sliding the Hard-Drive Assembly: Schritt 9, Bild 1 von 1
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Abschluss
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 250
