Zum Hauptinhalt wechseln
Dell Inspiron 1122 M102z Memory Modules Replacement
Was du brauchst
  1. Dell Inspiron 1122 M102z Memory Modules Replacement, Sliding the Battery: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Slide the battery release latches to the unlock position.
  2. Dell Inspiron 1122 M102z Memory Modules Replacement, Sliding the Battery: Schritt 2, Bild 1 von 1
    • Slide the battery out of the battery bay.
  3. Dell Inspiron 1122 M102z Memory Modules Replacement, Sliding the Battery: Schritt 3, Bild 1 von 1
    • Slide the battery into the battery bay, until it clicks into place.
  4. Dell Inspiron 1122 M102z Memory Modules Replacement, Loosen the Screw: Schritt 4, Bild 1 von 1
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  5. Dell Inspiron 1122 M102z Memory Modules Replacement, Lifting the Memory-Module Cover: Schritt 5, Bild 1 von 1
    • Lift the memory-module cover off the computer base.
  6. Dell Inspiron 1122 M102z Memory Modules Replacement, Spread Apart the Securing Clips: Schritt 6, Bild 1 von 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  7. Dell Inspiron 1122 M102z Memory Modules Replacement, Removing the Memory Module: Schritt 7, Bild 1 von 1
    • Remove the memory module from the memory-module connector.
  8. Dell Inspiron 1122 M102z Memory Modules Replacement, Align the Notch: Schritt 8, Bild 1 von 1
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  9. Dell Inspiron 1122 M102z Memory Modules Replacement, Sliding the Memory Module: Schritt 9, Bild 1 von 1
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  10. Dell Inspiron 1122 M102z Memory Modules Replacement, Sliding the Tabs: Schritt 10, Bild 1 von 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  11. Dell Inspiron 1122 M102z Memory Modules Replacement, Tighten the Screw: Schritt 11, Bild 1 von 1
    • Tighten the screw that secures the memory-module cover to the computer base.
Abschluss
Terrence15
79.243 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 97
