Einleitung
In this guide, we will show you how to remove and replace the Display Assembly.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  2. Disconnect the display cable and the camera cable from the system board connectors.
    • Disconnect the display cable and the camera cable from the system board connectors.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the two screws (one on each side) that secure the display assembly to the computer base.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Lift the display assembly off the computer.
    • Lift the display assembly off the computer.
  6. Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Route the Mini-Card antenna cables through the routing guides.
    • Route the Mini-Card antenna cables through the routing guides.
Abschluss
Terrence15
70.653 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 65
