Zum Hauptinhalt wechseln
Dell Inspiron 11z 1110 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 11z 1110 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the three screws that secure the hard drive assembly to the computer base.
  2. Dell Inspiron 11z 1110 Hard Drive Replacement, Pulling the Pull-Tab: Schritt 2, Bild 1 von 1
    • Pull the pull-tab on the hard drive bracket towards the right to disconnect the hard drive assembly from the interposer.
  3. Dell Inspiron 11z 1110 Hard Drive Replacement, Lifting the Hard Drove Assembly: Schritt 3, Bild 1 von 1
    • Pull the pull-tab on the hard drive bracket to lift the hard drive assembly at an angle and out of the hard drive compartment as shown in the illustration.
  4. Dell Inspiron 11z 1110 Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws that secure the hard drive bracket to the hard drive and remove the hard drive bracket.
  5. Dell Inspiron 11z 1110 Hard Drive Replacement, Replacing the Bracket: Schritt 5, Bild 1 von 1
    • Replace the hard drive bracket and the four screws that secure the NEW hard drive bracket to the hard drive.
  6. Dell Inspiron 11z 1110 Hard Drive Replacement, Placing the Hard Drive Assembly: Schritt 6, Bild 1 von 1
    • Place the hard drive assembly in the hard drive compartment.
  7. Dell Inspiron 11z 1110 Hard Drive Replacement, Connecting the Assembly: Schritt 7, Bild 1 von 1
    • Push the hard drive assembly towards the left until it is fully connected to the interposer.
  8. Dell Inspiron 11z 1110 Hard Drive Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the three screws that secure the hard drive assembly to the computer base.
Abschluss
To reassemble your computer, follow these instructions in reverse order.
Terrence15
79.243 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 937
