Einleitung
In this guide, we will show you how to remove and replace the Hard Drive.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
    • Lift the hard-drive assembly out of the computer base.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard-drive bracket off the hard drive.
    • Place the NEW hard drive in the hard-drive bracket.
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
    • Place the hard-drive assembly in the computer base.
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Abschluss
Terrence15
Mitglied seit 18.12.2017
70.258 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 20
