Zum Hauptinhalt wechseln
Dell Inspiron 11z 1120 Memory Module Replacement
Was du brauchst
  1. Dell Inspiron 11z 1120 Memory Module Replacement, Loosen the Captive Screw: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 11z 1120 Memory Module Replacement, Lifting the Memory-Module Cover: Schritt 2, Bild 1 von 1
    • Lift the memory-module cover off the computer base.
  3. Dell Inspiron 11z 1120 Memory Module Replacement, Popping up the Memory Module: Schritt 3, Bild 1 von 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  4. Dell Inspiron 11z 1120 Memory Module Replacement, Removing the Memory Module: Schritt 4, Bild 1 von 2 Dell Inspiron 11z 1120 Memory Module Replacement, Removing the Memory Module: Schritt 4, Bild 2 von 2
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 11z 1120 Memory Module Replacement, Align the Notch: Schritt 5, Bild 1 von 2 Dell Inspiron 11z 1120 Memory Module Replacement, Align the Notch: Schritt 5, Bild 2 von 2
    • Align the notch in the memory module with the tab in the memory-module connector.
  6. Dell Inspiron 11z 1120 Memory Module Replacement, Sliding the Memory Module: Schritt 6, Bild 1 von 1
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
  7. Dell Inspiron 11z 1120 Memory Module Replacement, Sliding the Tabs: Schritt 7, Bild 1 von 1
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  8. Dell Inspiron 11z 1120 Memory Module Replacement, Tighten the Screw: Schritt 8, Bild 1 von 1
    • Tighten the screw that secures the memory-module cover to the computer base.
Abschluss
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 69
