Zum Hauptinhalt wechseln
Dell Inspiron 11z-1121 Fan Replacement
Was du brauchst
  1. Dell Inspiron 11z-1121 Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Fan Replacement, Keyboard: Schritt 2, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement, Keyboard: Schritt 2, Bild 2 von 2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Fan Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement: Schritt 3, Bild 2 von 2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Fan Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement: Schritt 4, Bild 2 von 2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Fan Replacement, Fan: Schritt 5, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement, Fan: Schritt 5, Bild 2 von 2
    • Start by prying the outer casing of the laptop using the plastic opening tool. Start from the bottom and work your way around the edges.
  6. Dell Inspiron 11z-1121 Fan Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement: Schritt 6, Bild 2 von 2
    • Remove the outer casing to expose the motherboard.
    • Remove five .75 mm screws using a PH1 screwdriver.
    • Make sure to keep track of your screws.
  7. Dell Inspiron 11z-1121 Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove wireless wide area network (WWAN) card by sliding it out of position.
    • Make sure the wires attached to the WWAN card are not detached when doing this step.
  8. Dell Inspiron 11z-1121 Fan Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the two 0.9 mm screws that are holding down the screen.
    • Lift the screen up and towards yourself to detach the screen from the laptop.
  9. Dell Inspiron 11z-1121 Fan Replacement: Schritt 9, Bild 1 von 1
    • Lay the screen down and pry the left corner of the plastic casing that is located behind the screen.
  10. Dell Inspiron 11z-1121 Fan Replacement: Schritt 10, Bild 1 von 1
    • While holding screen, remove the motherboard by wiggling it around and pulling outwards.
    • In this step you are trying to pull the motherboard out from the VGA socket it is attached to in the back left corner of the laptop.
  11. Dell Inspiron 11z-1121 Fan Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 11z-1121 Fan Replacement: Schritt 11, Bild 2 von 2
    • Unscrew the two black 0.5 mm screws holding the fan in place.
    • Remove the fan by gently lifting the component upwards.
Abschluss
Cassidy Chen
289 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-5, Nance Fall 2016 Mitglied von USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I see there are a few more screws on the bottom. Can't we just unscrew those and take off the bottom panel?
bluejedi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,008
