Zum Hauptinhalt wechseln
Dell Inspiron 11z-1121 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 11z-1121 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 11z-1121 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 2 Dell Inspiron 11z-1121 Keyboard Replacement, Keyboard: Schritt 2, Bild 2 von 2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Keyboard Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 11z-1121 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 11z-1121 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 1-5, Nance Fall 2016 Mitglied von USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,522
