Zum Hauptinhalt wechseln
Dell Inspiron 11z-1121 Memory Modules Replacement
Was du brauchst
  1. Dell Inspiron 11z-1121 Memory Modules Replacement, Loosen the Screw: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 11z-1121 Memory Modules Replacement, Lifting the Memory-Module Cover: Schritt 2, Bild 1 von 1
    • Lift the memory-module cover off the computer base.
  3. Dell Inspiron 11z-1121 Memory Modules Replacement, Popping up the Memory Module: Schritt 3, Bild 1 von 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  4. Dell Inspiron 11z-1121 Memory Modules Replacement, Removing the Memory Module: Schritt 4, Bild 1 von 1
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 11z-1121 Memory Modules Replacement, Align the Notch: Schritt 5, Bild 1 von 1
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  6. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: Schritt 6, Bild 1 von 2 Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: Schritt 6, Bild 2 von 2
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  7. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Tabs: Schritt 7, Bild 1 von 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  8. Dell Inspiron 11z-1121 Memory Modules Replacement, Tighten the Screw: Schritt 8, Bild 1 von 1
    • Tighten the screw that secures the memory-module cover to the computer base.
Abschluss
Terrence15
79.243 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 163
