Einleitung
In this guide, we will show you how to remove the Display Assembly.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Follow the instructions in "Before Working Inside Your Computer." Disconnect the display ground wire from the EMI shield by unscrewing the captive screw.
  2. Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
    • Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
  3. Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
    • Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Disconnect the attached antenna cable from the Mini PCI card.
    • Disconnect the attached antenna cable from the Mini PCI card.
    • Close the display.
    • From the bottom of the computer, remove the two M2.5 x 5-mm screws labeled "D."
  6. From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  7. Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board. Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  8. Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
    • Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
  9. Lift the display assembly out of the computer base.
    • Lift the display assembly out of the computer base.
Abschluss
Terrence15
70.643 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 38
