Zum Hauptinhalt wechseln
Dell Inspiron 1210 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 1210 Hard Drive Replacement, Removing the Hard Drive Cable: Schritt 1, Bild 1 von 1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging (see "Protecting Against Electrostatic Discharge" in the safety instructions that shipped with your computer).
    • Remove the hard drive cable from the hard-drive system board connector.
  2. Dell Inspiron 1210 Hard Drive Replacement, Lifting the Hard Drive: Schritt 2, Bild 1 von 2 Dell Inspiron 1210 Hard Drive Replacement, Lifting the Hard Drive: Schritt 2, Bild 2 von 2
    • Lift the hard drive out of the hard drive compartment.
  3. Dell Inspiron 1210 Hard Drive Replacement, Detach the Cable: Schritt 3, Bild 1 von 1
    • Detach the hard drive cable from the hard drive cable connector.
  4. Dell Inspiron 1210 Hard Drive Replacement, Remove the Hard Drive: Schritt 4, Bild 1 von 1
    • Remove the hard drive from the rubber case.
  5. Dell Inspiron 1210 Hard Drive Replacement, Attaching the Hard Drive Cable: Schritt 5, Bild 1 von 1
    • To replace the hard drive, replace the rubber case onto the hard drive.
    • Attach the hard drive cable to the hard drive cable connector.
  6. Dell Inspiron 1210 Hard Drive Replacement, Placing the Hard Drive: Schritt 6, Bild 1 von 1
    • Place the NEW hard drive in the hard drive compartment.
  7. Dell Inspiron 1210 Hard Drive Replacement, Attaching the Hard Drive Cable: Schritt 7, Bild 1 von 1
    • Attach the hard drive cable to the hard-drive system board connector.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,028
