Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Follow the procedures in Before You Begin.
    • Follow the procedures in Before You Begin.
    • Remove the module cover (see Base Cover).
  2. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the module from the connector.
    • Remove the module from the connector.
  5. Align the notch in the module edge connector with the tab in the connector slot. Align the notch in the module edge connector with the tab in the connector slot.
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ziellinie
Terrence15
70.653 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 14
