Einleitung
In this guide, we will show you how to remove and replace the Display Assembly.
Was du brauchst
Peel off the pieces of tape that secure the display cable and touch-screen board-cable to the system board.
Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
Turn the computer over and open the display as far as possible.
Remove the screws that secure the display assembly to the palm-rest assembly.
Lift the display assembly off the palm-rest assembly.
Place the display assembly face down on the palm-rest assembly.
Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
Replace the screws that secure the display assembly to the palm-rest assembly.
Close the display and turn the computer over.
Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
