Einleitung
In this guide, we will show you how to remove and replace the Memory Modules.
Was du brauchst
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Remove the memory module from the memory-module slot.
Align the notch on the NEW memory module with the tab on the memory-module slot.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
