Zum Hauptinhalt wechseln
Dell Inspiron 13 7378 Wi-Fi Card Replacement
Was du brauchst
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: Schritt 3, Bild 3 von 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 2 von 2
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Gateway, Team 1-3, Saknee Spring 2022 Mitglied von Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 422
