Einleitung
This is a simple step-by-step guide on how to remove and replace a fan for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. This is a relatively easy task to complete and will take about 7 minutes.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
