Einleitung
This is a simple step-by-step guide on how to remove and replace the cooling fan for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. This is a relatively easy task to complete and will take about 7 minutes.
Was du brauchst
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
Unplug the fan from the motherboard by pulling the cable towards the fan. Then remove the fan.
