Zum Hauptinhalt wechseln
Dell Inspiron 13-5368 Screen Display Replacement
Was du brauchst
  1. Dell Inspiron 13-5368 Screen Display Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-5368 Screen Display Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-5368 Screen Display Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-5368 Screen Display Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger / pry tool to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 13-5368 Screen Display Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery straight up out of the housing.
  6. Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: Schritt 6, Bild 1 von 3 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: Schritt 6, Bild 2 von 3 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: Schritt 6, Bild 3 von 3
    • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
  7. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 7, Bild 1 von 1
    • Detach the black and white antenna cables from the WLAN card.
  8. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 8, Bild 1 von 1
    • Unplug the two display cables.
  9. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 9, Bild 1 von 1
    • Unscrew the screws that are securing the laptop's hinges.
  10. Dell Inspiron 13-5368 Screen Display Replacement: Schritt 10, Bild 1 von 1
    • Detach the display from the base.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S14-G6, Boczar Fall 2017 Mitglied von USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 40
Insgesamt: 2,717
