Einleitung
This is a simple step-by-step guide on how to remove and replace a touchpad for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. It is very easy to do and will take about 7 minutes.
Was du brauchst
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
Undo the clasps that hold the ribbon cables in place. Then, remove the ribbon cables.
Push up on the touchpad to release it from the housing. Then you can remove the touchpad.
