Zum Hauptinhalt wechseln
Dell Inspiron 13-7347 Touchpad Replacement
Was du brauchst
  1. Dell Inspiron 13-7347 Touchpad Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7347 Touchpad Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7347 Touchpad Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Touchpad Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Touchpad Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 3, Bild 3 von 3
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Touchpad Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: Schritt 5, Bild 1 von 2 Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: Schritt 5, Bild 2 von 2
    • Unplug the sliding connector.
    • The cord is extremely fragile.
  6. Dell Inspiron 13-7347 Touchpad Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Flip the cord upward.
  7. Dell Inspiron 13-7347 Touchpad Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 2.5 mm JIS #00 screws.
  8. Dell Inspiron 13-7347 Touchpad Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 8, Bild 3 von 3
    • Flip the metal plate upward.
    • Take out the metal plate completely.
  9. Dell Inspiron 13-7347 Touchpad Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 13-7347 Touchpad Replacement: Schritt 9, Bild 3 von 3
    • Remove the touchpad by lifting up the handle.
Abschluss
lee120496
643 Reputation
4 Anleitungen geschrieben
UC Davis, Team S20-G8, Lore Winter 2019 Mitglied von UC Davis, Team S20-G8, Lore Winter 2019
UCD-LORE-W19S20G8
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 572
