Zum Hauptinhalt wechseln
Dell Inspiron 13-7352 Cooling Fan Replacement
Was du brauchst
  1. Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Cooling Fan Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-7352 Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: Schritt 4, Bild 1 von 2 Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: Schritt 4, Bild 2 von 2
    • Remove the cord that runs from system board to the I/O board.
  5. Dell Inspiron 13-7352 Cooling Fan Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 13-7352 Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Remove the 3mm and 4mm screws holding down fan with the Phillips #0 head.
    • Disconnect the fan wire from the system board.
  6. Dell Inspiron 13-7352 Cooling Fan Replacement: Schritt 6, Bild 1 von 1
    • Lift the fan from the rest of the device by picking up a single side and separating it from device.
Abschluss
Chris Monte
411 Reputation
2 Anleitungen geschrieben
University of Tampa, Team 1-5, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 2,307
