Zum Hauptinhalt wechseln
Dell Inspiron 13-7352 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 13-7352 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7352 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7352 Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-7352 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Dell Inspiron 13-7352 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Locate the Hard Drive.
    • Remove the two 3mm screws from Hard Drive with the Phillips #0 head.
    • Disconnect the wire attached to the system board by lifting up the tape.
    • Remove the tape tab from the Hard Drive by lifting the tape up and off of the Hard Drive unit.
  5. Dell Inspiron 13-7352 Hard Drive Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 13-7352 Hard Drive Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 13-7352 Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Once disconnected from the tape and the connector is free, lift the Hard Drive unit from the rest of the device by grasping each side with thumb and index or middle finger.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
University of Tampa, Team 1-5, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 9,574
