Zum Hauptinhalt wechseln
Dell Inspiron 13-7353 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 13-7353 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery up and out of the computer.
  4. Dell Inspiron 13-7353 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Unplug the hard drive cable from the motherboard.
  5. Dell Inspiron 13-7353 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Using the Phillips #000 screwdriver, remove two 3mm screws from the hard drive frame.
  6. Dell Inspiron 13-7353 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Lift the hard drive up and out of the computer.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 26
Insgesamt: 888
