Zum Hauptinhalt wechseln
Dell Inspiron 13-7353 Palmrest Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: Schritt 1, Bild 3 von 3
    • Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
    • Detach and remove the Bottom Base Cover using an opening tool to pry it off.
  2. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Unplug and gently pull the hard drive cable to loosen it.
    • Remove the 2 - M2 x 3mm screws.
    • Remove the Battery.
  3. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the 2 - M2 x 3mm hard drive screws.
    • Remove the Hard Drive.
  4. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Unplug the speaker cable.
    • Remove the Speakers.
  5. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Unplug the fan cable.
    • Unplug and remove the daughter board cable.
  6. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Unplug the antenna cables.
    • Unplug the power button cable.
  7. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the 1 - M2 x 3mm screw.
    • Remove the USB / SD Card Circuit Board.
  8. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Remove the 1 - M2 x 3mm and 1 - M2 x 2mm Wafer screw.
    • Remove the Cooling Fan.
  9. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Loosen the screws.
    • Remove the Heatsink.
  10. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the 2 - M2 x 3mm bracket screws.
    • Remove the LCD cable bracket.
  11. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Unplug the LCD cable.
    • Unplug the touchscreen cable.
  12. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 12, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 12, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 12, Bild 3 von 3
    • Open the screen.
    • Loosen the LCD cable and peel it off of the base (highlighted with arrow).
    • Remove the 3 - M2.5 x 8mm hinge screws.
  13. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the screen assembly.
    • You may need to pull the hinges up.
  14. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 14, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 14, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 14, Bild 3 von 3
    • Unplug the cable.
    • Remove the DC Jack.
  15. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 15, Bild 2 von 2
    • Loosen the keyboard cable tape.
    • Loosen the keyboard cable latches.
    • Unplug the keyboard cable.
  16. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 16, Bild 1 von 1
    • Unplug the keyboard backlight cable.
    • Unplug the touchpad cable.
  17. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 17, Bild 1 von 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 17, Bild 2 von 2
    • Remove the 1 - M2 x 2mm Wafer screw.
    • Remove the Motherboard.
    • The piece remaining is the Palmrest Keyboard.
  18. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 18, Bild 1 von 1
    • You can further disassemble by removing the touchpad.
  19. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 19, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 19, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 19, Bild 3 von 3
    • Unscrew the 4 - 2x2mm wafer screws.
    • Peel back any tape holding the back plate on.
    • Lift and remove back plate.
  20. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 20, Bild 1 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 20, Bild 2 von 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: Schritt 20, Bild 3 von 3
    • Peel back under-button tape.
    • Remove touchpad.
    • You have now stripped the keyboard! It is ready to be replaced.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Angehängte Dokumente
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 7,303
