Zum Hauptinhalt wechseln
Einleitung
If you notice your computer programs or computer are slowing, then this guide may be able to help. This guide will show you how to replace the RAM in a few steps.
Ersatzteile
Keine Ersatzteile angegeben.
  1. WARNING :  Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer . After working inside your  computer, follow the instructions in After working inside your computer.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer . After working inside your computer, follow the instructions in After working inside your computer.
    • Close the display and turn the computer over
  2. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
    • Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
  4. Before opening device, ensure that all data is backed up on a hard drive to prevent data loss. Loosen and then unplug the hard drive cable.
    • Before opening device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Remove 2 M2 3mm screws, using the Phillips 1 screwdriver. Remove the battery.
    • Remove 2 M2 3mm screws, using the Phillips 1 screwdriver.
    • Remove the battery.
  6. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM.
    • Pry open the clips and remove the RAM.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 10
Insgesamt: 412
