Einleitung
If you notice your computer programs or computer are slowing, then this guide may be able to help. This guide will show you how to replace the RAM in a few steps.
Was du brauchst
Close the computer display and turn the computer over so that the base of the computer is facing up.
Remove the ten screws that secure the base cover to the base of the computer.
Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
Remove the battery.
Pry open the two clips.
Gently lift the RAM stick and pull it out of the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
