Einleitung
If you notice your computer screen is damaged and needs to be replaced, this guide may be able to help. This guide will show you how to replace the display screen in a few steps.
Was du brauchst
Close the computer display and turn the computer over so that the base of the computer is facing up.
Remove the ten screws that secure the base cover to the base of the computer.
Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
Remove the battery.
Pry open the two clips.
Gently lift the RAM stick and pull it out of the motherboard.
Unplug the daughterboard cable in two places, then remove the daughterboard.
Unplug the fan cable.
Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
Remove the cooling fan from the laptop.
Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
Remove the heat sink.
Remove the screws from the LCD cable bracket.
Remove the LCD cable bracket.
Unscrew 2 M2.5 7mm screws, using the Phillips 1 screwdriver, on the right screen hinge.
Unscrew 1 M2.5 7mm screw, using the Phillips 1 screwdriver, on the left screen hinge.
Remove the tape outlined in red.
Adjust the screen so that the laptop is open flat against the surface.
Remove the LCD display screen by pulling it gently away from the back.
2 Kommentare
Wow. Thank you so much. I will do this when I get my replacement screen.
Finally tried this and noticed you left out the most difficult part which is the part of putting on the actually replacing the screen. This is only for removal of the screen. And the instructions are definitely not the same backwards. You left out the part with the cable/wires closing with the hinges being the most difficult part. I actually forced the cable too much stripped the cable that goes around the new screen. Have to order new cable now ugh
