Zum Hauptinhalt wechseln
Dell Inspiron 13-7353 Speakers Replacement
Was du brauchst
  1. Dell Inspiron 13-7353 Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Speakers Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery up and out of the computer.
  4. Dell Inspiron 13-7353 Speakers Replacement, Speakers: Schritt 4, Bild 1 von 1
    • Unplug the speaker wire from the motherboard.
  5. Dell Inspiron 13-7353 Speakers Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the connecting wire from underneath the wire brackets from the back of the computer.
  6. Dell Inspiron 13-7353 Speakers Replacement: Schritt 6, Bild 1 von 1
    • Lift up both speakers away from the computer.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 18
Insgesamt: 160
