Zum Hauptinhalt wechseln
Dell Inspiron 13-7359 Speaker Replacement
Was du brauchst
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: Schritt 2, Bild 1 von 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13-7359 Speaker Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13-7359 Speaker Replacement: Schritt 3, Bild 3 von 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 13-7359 Speaker Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 13-7359 Speaker Replacement: Schritt 4, Bild 3 von 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 Dell Inspiron 13-7359 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 13-7359 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 13-7359 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Baylor, Team S1-G6, Johnson Spring 2018 Mitglied von Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 24
Insgesamt: 416
