Zum Hauptinhalt wechseln
Dell Inspiron 13-7370 Fan Replacement
Was du brauchst
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7370 Fan Replacement, Fan: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7370 Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-7370 Fan Replacement: Schritt 2, Bild 2 von 2
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 13-7370 Fan Replacement: Schritt 3, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 13-7370 Fan Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 13-7370 Fan Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 13-7370 Fan Replacement: Schritt 5, Bild 3 von 3
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the fan from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zayed Azam
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G6, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G6, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G6
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 742
