Zum Hauptinhalt wechseln
Dell Inspiron 13-7373 Motherboard Replacement
Was du brauchst
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 13-7373 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 13-7373 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: Schritt 5, Bild 1 von 1
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: Schritt 7, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: Schritt 8, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: Schritt 11, Bild 1 von 3 Dell Inspiron 13-7373 Motherboard Replacement: Schritt 11, Bild 2 von 3 Dell Inspiron 13-7373 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Gently lift up on the motherboard to remove it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
John Egan
485 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 32
Insgesamt: 1,430
