Zum Hauptinhalt wechseln
Dell Inspiron 1300 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 1300 Hard Drive Replacement, Loosen the Captive Screws: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 1300 Hard Drive Replacement, Lifting the Cover: Schritt 2, Bild 1 von 1
    • Lift the cover off the computer and set it aside.
  3. Dell Inspiron 1300 Hard Drive Replacement, Sliding the Hard Drive: Schritt 3, Bild 1 von 1
    • Slide the hard drive carrier away from the screw holes, and then use the tab to lift the hard drive straight up to remove it from the computer.
  4. Dell Inspiron 1300 Hard Drive Replacement, Installing the NEW Hard Drive: Schritt 4, Bild 1 von 1
    • NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
    • Seat the NEW hard drive into the bay, and then slide it into the connector by sliding it toward the screw holes until it is fully seated.
  5. Dell Inspiron 1300 Hard Drive Replacement, Replace the Cover: Schritt 5, Bild 1 von 1
    • Replace the cover and tighten the screws.
Abschluss
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 1,270
