Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
  1. Make note of the cable routing and carefully remove the antenna cables from their routing guides. Pull the cables with their connectors through the system board so that they are clear of the computer base.
    • Make note of the cable routing and carefully remove the antenna cables from their routing guides. Pull the cables with their connectors through the system board so that they are clear of the computer base.
  2. Remove the two M2.5 x 5-mm screws from the computer base.
    • Remove the two M2.5 x 5-mm screws from the computer base.
    • NOTE: Note how the display cable and the camera cable have been routed through their routing guides.
  3. Pull the display cable tab to disconnect the display cable from the system board connector.
    • Pull the display cable tab to disconnect the display cable from the system board connector.
  4. Disconnect the camera cable from the system board connector.
    • Disconnect the camera cable from the system board connector.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Make note of the cable routing and carefully dislodge the antenna cables and the rest of the cables from their routing guides. Pull the cables away, so that they are clear of the palm rest.
    • Make note of the cable routing and carefully dislodge the antenna cables and the rest of the cables from their routing guides. Pull the cables away, so that they are clear of the palm rest.
  7. Remove the two M2.5 x 5-mm screws from either side of the display assembly.
    • Remove the two M2.5 x 5-mm screws from either side of the display assembly.
  8. Lift and remove the display assembly from the computer base.
    • Lift and remove the display assembly from the computer base.
  9. Route and connect the display cable to the connector on the system board.
    • Route and connect the display cable to the connector on the system board.
    • Route and connect the camera cable to the connector on the system board.
    • Carefully route the WLAN antenna cables into their routing guides on the palm rest and through the computer base.
  10. Replace the two M2.5 x 5-mm screws on each side of the display assembly.
    • Replace the two M2.5 x 5-mm screws on each side of the display assembly.
  11. Turn the computer over and replace the two M2.5 x 5-mm screws on the computer base.
    • Turn the computer over and replace the two M2.5 x 5-mm screws on the computer base.
  12. Carefully route the WLAN card antenna cables through their routing guides and connect them to the WLAN card.
    • Carefully route the WLAN card antenna cables through their routing guides and connect them to the WLAN card.
Ziellinie
Terrence15
70.547 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 15
